SteveOS Posted August 2 Posted August 2 Hi team, so I have been experiencing issues with the HEXos dock not being available randomly. Been using Dozzle and it looks like every 21 minutes or so the container restarts. (Nick, you should have some of these logs in your dms) Nick and Gerod have been helping trouble shoot various things over the last month. I have Deleted HEXos from truenas and reinstalled it at least twice now. And the issues has not resolved. It has gotten bad enough that I was unable to update nextcloud and have had to delete it. But cannot install it through HEX because the container resets and the install stalls. My question is: - Can I reinstall HEXos from the USB? Would that help? - If I do a fresh install will the apps and data remain or will that reset everything? - If I don't reset the pools, the data should remain? Can I reinstall the apps and run them with the existing confis? Thanks.
mill3000 Posted August 6 Posted August 6 Hello, we have a bunch of fixes coming for this very shortly. It's tied up with buddy backups which is why we haven't pushed it yet. Just know it's coming out very soon! 1
