This is important for people to maintain up to date information in opening posts. A great example of this is in custom scripting for app. The author needs to be able to keep the opening post up to date and they can't after a few minutes.
I understand there might be some hesitancy to allow infinite editing due to abuse but that's why post quotes and edit history exist.
Edited by NAS
I wonder if they think quoting yourself in another post is an acceptable alternative.  I would like this ability because I have created a couple posts where I had a problem and reported it.  As I looked at the problem I would have changed the post several times as I discovered mistakes I made and the results of the self heal we hear so much about.  I could have reported, ranted and resolved in one neat post.
@NASI see where you are coming from and will mention it to the team however at this time the best solution I can offer you is
To DM me whenever you would like your posts edited and I will happily help you with that.
  • Thanks 1
