Hello all
I took the plunge and bought and installed HexOS on my kickstarter backed Orico cf56 pro as the inbuilt OS is absolutely **** and i mean **** as the limitation of only able to create one SMB share and only one. and the amount of data it tried to send back is concerning but that’s in hand as my Firewalla Gold Plus is a god send when stooping that type of thing
For those who wish to install HexOS on these i would suggest HexOS as this was a little frustrating as the only monitor i could get a signal was my Samsung G9 super ultra wide and the install screen was stretched so much it was hard to see the install instructions but it is possible and is an improvement but one think i have noticed is that that CPU Thread 13 to 16 does not have a Temp next to it in the web interface
For reference below is the Setup on my Orico cf56 pro
CPU: 12th Gen Intel® Core™ i5-1240P
RAM: 16GB DDR5 5600mhz
HDD: 5 Seagate Ironwolf Pro 16TB
NVME: 2tb ORICO (this is the Install Drive for Hex OS as I'm leaving the inbuilt 128gb for the Original OS i have just taken this out of the boot look on the Bios)
LAN: 10GbE*2
My next update in the coming months on this would be to increase the RAM to 32GB and I'm currently looking at installing "geekau / mediastack" on this as i have already installed Portaner enterprise thought the TrueNAS interface after i have coped all my Data from my ageing Drobo5n.
any questions welcome and also any suggestions welcome.
This is very cool. It might be TrueNAS not seeing a temp on those other cores due to some issue. HexOS just takes the TrueNAS information and puts it on our graph. As the new version of TrueNAS comes out and HexOS offers the update for them maybe this will just resolve itself. I looked up the model and it's a pretty cool little NAS.
mill3000
This post was recognized by mill3000!
"Great Information."
hikari was awarded the badge 'Helpful' and 20 points.
The limited number of temperature values is intentional, as far as TrueNAS is concerned.
https://forums.truenas.com/t/truenas-scale-24-10-2-is-now-available/32410/2
i5-1240P has 12 physical cores, where 4 are performance cores with SMT that brings the total logical cores to 16. This means the expected (and shown) behavior is 12 temperature values and 16 usage values.
