Soid Posted June 7 Posted June 7 I'd like a way to set up fan behavior within the HexOS dashboard (or curate an app that handles it). My motherboard bios doesn't allow me any control on drive temps, so my drives are always a little hotter than I'd prefer. 2
Mobius Posted June 7 Posted June 7 Unfortunately fan controller functionality is not built into truenas scale at this time and there are no fan controller apps on the truenas app catalog for us to curate. 2 1
Soid Posted June 8 Author Posted June 8 I appreciate the response. I imagine if it was easy somebody probably would have already integrated it into TrueNAS. Maybe you can use you relationships with the leadership and make it a feature request ;) 1
mill3000 Posted June 12 Posted June 12 Everything may last longer when you keep them in within a certain temp range. I've seen a lot of things over time for hard drives. The issue the better you cool the drives the more you give up. In data centers fans are running full speed most the time. In a house you usually don't want all that noise. We like hot swap bays so it's easy to replace a drive but that means you got drives right next to each out sharing all the head each drive make. I've seen 5 inch drive bay adapters for hard drive that turn a 3.5 inch drive into a 5 inch size drive which is 1.5 inches of heat sync around the drive to give the drive the best way to cool down with air cooling. I've purchased it and ran it in a server for years like this. You can't have this and make it hotswapable. Had to shutdown the server and open it up and unscrew it all to replace drives. I didn't have any fail which is the point of it but when increasing the size you have a lot more work to do. Thanks for posting your request. If there was a tool like this we'd think about adding it. Thanks 1
Soid Posted Tuesday at 07:33 PM Author Posted Tuesday at 07:33 PM (edited) Hey! Thanks for adding fan control! Looks like my mobo isn't supported though. :( Edited Tuesday at 07:36 PM by Soid
