Myrddin Emrys Posted 3 hours ago Posted 3 hours ago Two pools, one namespace. Frequently accessed files promote to the SSD/NVMe pool; files idle past a threshold (or evicted under capacity pressure) demote to the HDD pool. Transparent to SMB/NFS clients and to apps — the path never changes. I use Windows Storage spaces on my PC, and the ability to just 'have a drive' that has mixed tiers of storage, and the games I play all the time load fast, but my media and games I haven't played recently get auto-evicted to HDD. The end result is it feels like ALL of it is fast (even though only 20% of it is), without any fuss or bother. Note that this is not L2ARC: data physically moves (on a nightly cron) and the slow tier holds the only copy of cold data, and the hot tier holds the only copy of hot data, but there's no visible change... the path doesn't change, it's all just one drive, and some of it is fast and some is slow and the system automates it so I never need to think about it. The only time I notice it is booting up a game I haven't played in ages, and if I keep playing it then in a day or so it's on the hot tier and it's fast again.
