KarmaKuzy Posted 9 hours ago Posted 9 hours ago (edited) Hi, I looked to see if these have been mentioned in other posts, but didn't find them (or didn't look hard enough lol). I'd like to be able to enable Anywhere/ remote access for custom apps. In my case, I installed foundry via YAML using felddy/foundryvtt. I wanted to make it accessible for my TTRPG group to acces it through a URL like "foundry.myurl.com" instead of manually doing it myself or using a port forwarding method like taiscale or some DNS (DDNS?) stuff I haven't researched yet. Unfortunately, Anywhere / remote access isn't available in that custom app in the HexOS dashboard. Please make that possible. Also, I'd like to see FoundryVTT curated with the option to select which version it installs and the ability to install it more than once as separate apps. Assuming that is possible for things that aren't already in the Discover Apps section of TrueNAS. Finally, I'd like to know if the speed of Anywhere will be raised up from 10 Mbits? I noticed that it is way too little for Jellyfin and is probably the case for a lot of other apps that need higher speeds. Thanks for reading! Edited 9 hours ago by KarmaKuzy
Mobius Posted 50 minutes ago Posted 50 minutes ago I will have to get back to you about enabling hexos anywhere with custom apps. as for the speed of anywhere we chose 10Mbit for the initial roll out. It may change in the future. While it is not enough for direct playback of a 4k blu ray the bitrate supported are higher than what for example netflix offers at 1080p
