Hi everyone,
Finally getting to building my nas. I am repurposing an old gaming computer.
AMD Ryzen 5 2600X
32GB RAM
ASRock x470 Master SLI/ac
Zotac GTX 1080 (probably won't leave it in the nas)
12x 10TB HDDs
The mother board has 6 SATA ports, but I need more to use all of my hard drives.
I intend to add some of my old SSDs to the build for the OS and scratch/metadata.
I am looking for advice on what expansion card I should get. I have been looking at getting 2x LSI 9211-8i. Not sure if that's the best to get.
Any advice on expansion cards or the build would be appreciated.
I can't help on the expansion card, but AMD Ryzen 1000-3000 Series tends to freeze with HexOS/TrueNAS. To fix this, you have to disable C-States.
Also the GTX1080 is no longer supported only 2000 Series or higher is supported.
I don't know what gpu acceleration there is in hexos, I was only going to keep it in for troubleshooting. Will remove it to save on power.
Thanks for the info on c-states.
I was reading into it and got the same info. Especially for 16 drives, double the heat and needs a 6pin for power.
I ended up getting a LSI 9400-16i
