jerod Posted August 5 Posted August 5 The translation platform is live. Thanks to everyone who volunteered in this thread. Here are the instructions to get started. Where to go Head to translate.hexos.com and click Sign in. It uses your existing HexOS account, so there's nothing to register and nothing to be granted. If you can log in to HexOS, you can start translating right now. What you'll find We're running Weblate, the same open-source translation platform used by projects like Fedora and LibreOffice. Everything happens in your browser: no tools to install, no technical background needed. Just you, the English text, and a box to type your translation into. There are about 2,800 strings that make up the HexOS interface, and you can filter by area (storage, apps, tasks, and so on) if you'd rather focus on one corner at a time. Getting started Sign in at translate.hexos.com Open the Deck component and add your language (or join one that's already started) Start translating. Weblate saves as you go, and you can stop and pick it back up whenever you like. Same as Jon said: no deadlines, no commitments A few things worth knowing Placeholders like `{name}` or `{count}` need to stay exactly as they are. Move them around to fit your grammar, just don't translate what's inside the braces. Brand terms (HexOS, Command Deck, TrueNAS, ZFS) stay in English everywhere. They're marked in the built-in glossary so you don't have to memorize them. Not sure about a string? Leave a comment on it right in Weblate. We monitor those, and other translators can weigh in too. How your work reaches users Every translation goes through a review step before it ships, so don't worry about making mistakes. Nothing goes live until a reviewer approves it. We'll mark you all as reviewers once you start here soon, and once a language reaches 60% approved coverage, it ships with the next HexOS release and appears in the language picker. Below that threshold, the lang simply isn't offered yet, so nobody ever sees a half-translated interface. New strings will flow into Weblate automatically as we build new features, and the platform should email you when there's new material in your language. The full guide (with translation guidelines and how everything works under the hood) lives on the docs site: Translating HexOS. Let me know if you have any questions or something is off. Thank you! 3
jerod Posted August 7 Posted August 7 One question for the group: Weblate can show machine translation suggestions alongside each string as you work (from services like DeepL or Google Translate). You'd see the suggestion and decide whether to use it, tweak it, or ignore it on a per-string basis. Would that be helpful, or do you prefer working from a blank slate? We'll go with whatever the majority prefers.
Cantos Posted August 7 Posted August 7 6 hours ago, jerod said: One question for the group: Weblate can show machine translation suggestions alongside each string as you work (from services like DeepL or Google Translate). You'd see the suggestion and decide whether to use it, tweak it, or ignore it on a per-string basis. Would that be helpful, or do you prefer working from a blank slate? We'll go with whatever the majority prefers. Suggestions would be great. It was confusing to me seeing that the Automatic suggestions sections are empty (until there is a translation). I would be against filling automatic suggestions as "needs editing" translations, though.
Cantos Posted August 7 Posted August 7 Actually, I am getting suggestions like these: Where the translation and the suggested change are identical, but it still looks like it is suggesting it.
jerod Posted August 7 Posted August 7 7 hours ago, Cantos said: Actually, I am getting suggestions like these: Where the translation and the suggested change are identical, but it still looks like it is suggesting it. That suggestion's Origin is coming from a similar string inside of Deck. I have just enabled Google Cloud Translate API that you ALL can access from the Automatic suggestions tab. 1
AppelBe Posted August 18 Posted August 18 (edited) Dutch native Beglium: Flemmish region. Edited August 18 by AppelBe added extra info
Surendra Posted August 22 Posted August 22 I can help in Tamil - India which is one of the oldest surving language as of today. I'm a native Tamil speaker.
Taedeus Posted August 23 Posted August 23 Hello Everyone, When the time's come, i would be more than happy to help with Hungarian translation.
jonp Posted September 9 Author Posted September 9 Closing this thread as we are now LIVE with Community Translations via https://translate.hexos.com 2
