Aplication problems should i wipe and try again?
I have not been able to get HEXOS working the way i would like in the past year or so
All i want it a photo backup (Immich) and if im able to have a plex server running as well i would love that.
I inisaly tried to use a old computer but i have had so many problems that i thought were hardwear problems so i baught a new system just for HEXOS and i thought it would just work.
I did have a flood in my basment and had to turn everything off for the beter part of 4 months well it was getting fixed. I was all excited thiking alot would have changed in hex os in that time frame but its worse now for me then it was.
Im wondering if i just wipe and start again if i could fix some of the priblems.
What do you all thing?
Thanks
Andrew
Well you haven't told us about any of the problems you are facing, so it's impossible for us to say.
But if you don't have anything important on your system right now, then by all means reinstall the newest HexOS version and try to reinstall your apps from the beginning.
If you are still facing issues then post them here on the forums and we will likely be able to help you out 😊
