lostboykev Posted January 20 Posted January 20 Asus PRIME B450M-A mobo (6 sata ports) 32GB of DDR4 2666MHZ Ryzen 5 3600 MSI Nvidia 1080 Ti 11GB 500GB SATA boot drive 4 WD Red 10TB Raidz2 Cooler Master MasterBox Q300L Micro-ATX Case Drives are separated by plastic shims and thick 3M tape which I'm hoping will reduce the vibration between them. And since I ran out of room I have one standing vertical. Two fans in the front and one in the back. Drive temps stay below 40C 1 Quote
Dylan Posted January 21 Posted January 21 @lostboykev Did you configure the raidz2 pool via TrueNAS? 1 Quote
lostboykev Posted January 21 Author Posted January 21 21 hours ago, Dylan said: @lostboykev Did you configure the raidz2 pool via TrueNAS? Yes I did. I basically ignored the optional settings still being brand new TrueNAS and HexOS did the rest on initial configuration. Plex with GPU transcoding check Immich auto syncing my photos check It has been stable and basically forgettable on the maintenance side of things since day one beyond updating my docker containers. Life is good. Quote
