Anyone had success running on NAS hardware?
Curious if anyone has had success running on something like an old synology NAS or something similar that has three storage bays.
Wondering if i can get a used one for cheap and add some drives to it to test things out and maybe split off the storage component of my system into a smaller, lower power device than the PC that I have currently running everything
I'm not sure that you can easily install anything on a Synology NAS, they are pretty locked down and would require a lot of tinkering to even install Hexos. So I would not go down that route.
Also make sure that you get something with a video output, or else installation and management in case you locked yourself out will be a nightmare. Also it is not possible to use the boot drive in a Pool, meaning if you have a 3 storage bays, 1 drive will be used as a boot driving, leaving you with only 2 drives left. Take this into consideration, that you also need space for a dedicated boot drive.
