GabeL Posted 6 hours ago Posted 6 hours ago Hopefully this is the right place for this. We have been running our HexOS server about a year and just recently one drive has a degraded status. Just wondering what this means/what I should do. Disk 7 ST18000NM003D-3DL103 Capacity 18 TB Type Hard disk drive Healthy Yes Serial ZVTGGZES Device sdh Status DEGRADED Temperature 33° C Quote
Dylan Posted 1 hour ago Posted 1 hour ago Hi @GabeL This typically means one of three conditions has been met: A drive has failed A connection issue There are read/write errors. If the drive has failed, it should be replaced. If somehow a drive experienced a connection failure, reset connections and restart. Read/write errors are indicative of a drive ABOUT to fail and that drive should either be repaired or replaced. Quote
