Biem Posted November 27, 2025 Posted November 27, 2025 Hi there, Idk if this is the right place where to post this but here i am Im new to all this but i want to build a homeserver but dont know what specs it needs. Things i want to use the homeserver for: - Running Plex for movies and series - Storing family photos - Running gameserver for friends - Running home assistant - running hexos ofcourse But my question is what specs do i need im willing to use secondhand stuff and im looking for something that i dont have to upgrade for some time except the amount of storage Quote
Mobius Posted November 27, 2025 Posted November 27, 2025 1 hour ago, Biem said: Idk if this is the right place where to post this but here i am no worries Biem, moved you to the right spot 1 hour ago, Biem said: But my question is what specs do i need im willing to use secondhand stuff So seems like you have a fairly common use case withI he addition of game servers. The requirements for game servers do differ depending on game and the scale (like if you plan to make a sever say 100+ will join) so you may want to look up that part yourself As for the rest you should easily get by with some of the cheaper intel cpus available something like an intel i5 8400 or 8500 should be more than strong enough those intel cpus have integrated gpus so you don't have to spend extra on a graphics card and they support intel quick sync which just means they are great for plex. Make sure any motherboard you get does not have a realtek nic (network interface card), you can usually find out on the motherboard webpage or on the pcpartpicker page for the motherboard. for cases i like recommending the jonsbo n4 since its a fairly compact case that has 6 hdd bays and a relatively good value. The downside with the n4 is that it will only fit smaller sized power supplies and motherboards which may cost more than full size. for you boot drive i suggest getting a cheap and small ssd. any space left over on it after the os is installed cannot be used. I would suggest no less than 16gb of ram for you. now depending on your budget you could get a stronger cpu or more ram. 1 Quote
ubergeek Posted December 12, 2025 Posted December 12, 2025 So I have played with a lot of different hardware on my HexOs journey. For the time I have landed with using a i3 8350k 32gb of ram and running 16 drives. For your use case the storage is going to be your money pit. Without knowing where exactly where your needs are I could say make sure you bulk up there where as in RAM starting with 16gb will get you going but having more will help ZFS Cache. Quote
