marvin.the.robot Posted 11 hours ago Posted 11 hours ago I know it would probably be a big project and there is still a lot of work to do on the current build. But if you could add some kind of hot/cold storage automation wizard that would be awesome. Quote
marvin.the.robot Posted 9 hours ago Author Posted 9 hours ago After doing a little research, I might try the following and see if it will work: setup a Z1 pool of ssd's and a Z1 pool of hdd's, then use MergerFS to manage the hot/cold storage Quote
