renesdk Posted August 27 Posted August 27 Right now I have system running: Intel 4770K 16 GB DDR3 RAM LSI M5015 HBA (up to 8 disks) with a PCI-E Extender card (so it was ready for up to 16 disk total) running in RAID 6 8x Seagate IronWolf 2 TB Windows 2022 I’m planning to switch to HexOS once it’s closer to final (I grabbed a license back when they were cheap). Before that, I’ll need to back up my current media, which I already have plans for. How well does HexOS/TrueNAS Scale handle major hardware upgrades (CPU, motherboard, RAM) after switching? And what’s the cheapest HBA that can support up to 16 drives in IT-mode? Quote
Mobius Posted August 28 Posted August 28 @ubergeek has swapped out his hardware many times iirc. as long as boot drives stay the same, its fairly straight forward swapping parts. 6 hours ago, renesdk said: And what’s the cheapest HBA that can support up to 16 drives in IT-mode? realistically its probably the lsi 9300-16i but that one chugs on electricity and outputs a lot of heat so you would need a dedicated fan for it and in the long run itll be more expensive. i personally bought an oem variant of the 9400-16i for not that much more than 9300s are going for on ebay. i forget the model numbers, probably best you just ask chat gpt what the oem model numbers are Quote
ubergeek Posted August 28 Posted August 28 6 minutes ago, Mobius said: @ubergeek has swapped out his hardware many times iirc. as long as boot drives stay the same, its fairly straight forward swapping parts. realistically its probably the lsi 9300-16i but that one chugs on electricity and outputs a lot of heat so you would need a dedicated fan for it and in the long run itll be more expensive. i personally bought an oem variant of the 9400-16i for not that much more than 9300s are going for on ebay. i forget the model numbers, probably best you just ask chat gpt what the oem model numbers are thats what im running is the 9100 link to the eby seller i used Quote
renesdk Posted September 2 Author Posted September 2 Thank you both for the answers. I'll look into it and start saving up for both the drive fra a complete backup of my media data and the HBA card for future HexOS use. Quote
