Hey,
im trying to install plex. I go to applications - plex and click on install.
The wheel is spinning and after appr. 30s the install button reappears. The folders (media, movies,...) are were created, but the app isnt running.
I already tried to manually put in the dns servers that my router is using. I also checked if dns is working by pinging google.de from the truenas shell.
Please halp :)
On 2/25/2025 at 1:47 PM, Daedalus said:
I'm not able to install any apps, for some reason. Whenever I click on the 'install' button for Plex/Immich, it goes into a 'loading' circle for a couple of seconds, then returns to the download icon.
Relevant information:
This is a brand-new install of HexOS, having only just gotten the hardware together for a NAS. I ran through the install, but during web setup I accidentally went to the TrueNAS setup interface (because I followed the IP address that was displaying on the NAS's screen) and created a user, pool, etc through that. At this point, I was also able to install some apps through the TrueNAS interface, including Plex and Immich.
After that, and when attempting to figure out how to actually use the storage, I realized my mistake of accessing TrueNAS and navigated to the main HexOS setup. However, as my prior means of setup didn't create the basic folders, plus encountered a couple of other oddities, I attempted a 'Reset' to try and get the install back into the normal setup.
The Reset worked, but it did not create the structure I was looking for. At that point, I decided I'd just try doing it manually, and moved on.
Which brings me to the point I'm at now, where HexOS seems to be working normally (I was able to set up a computer backup to it and connect to a shared folder), but I'm unable to download any apps.
Help is appreciated.
Thanks.
On 2/25/2025 at 9:59 PM, Mobius said:
So when you create a pool with the truenas interface, hexos doesn't automatically setup permissions.
You will have to go back into the truenas ui and set your pool as the applications pool. Once that is done, one click hexos app installations should work again,
9 hours ago, Sonic said:
I know this issue occurs when a pool is created via Truenas. Did one of you created a pool via Truenas?
I didn’t. My pool was created with n HexOS
