migcooper Posted Friday at 12:34 PM Posted Friday at 12:34 PM Hi all as per the title one of my HDDs is faulty and i will be replacing it, the issue i have is that i have no spare SATA ports so the question is, can i shutdown the server, physically replace the damaged HDD with new one and then restart? or should i get a PCIE SATA card first and connect the new drive there and do the replacement via the UI? By the way, i know the exact one since its the only WD in the pool, so there is no chance of mixing things. Thank you Mig Quote
Dylan Posted Friday at 01:03 PM Posted Friday at 01:03 PM Hi @migcooper I would follow THESE instructions when replacing your disk. 2 Quote
Sonic Posted Friday at 01:23 PM Posted Friday at 01:23 PM @jonp, In case of HDD faillure it would great if HexOs guides the user with the HDD replacement. A small wizard with a few questions and then advice: do this, do that. Especialliy for non tech users it will make a big difference. Users will be nervous in case of HDD faillure. I think simple, low effort feature with big impact. Just my 2 cents. 2 Quote
migcooper Posted Friday at 01:25 PM Author Posted Friday at 01:25 PM 22 minutes ago, Dylan said: Hi @migcooper I would follow THESE instructions when replacing your disk. Perfect, thank you so much for this 😉 1 Quote
migcooper Posted Friday at 06:51 PM Author Posted Friday at 06:51 PM Quick note following the replacement, worked a treat. Resilvering almost done now. Just to mention as well that I have hot plug selected in the bios for sata drives Regards 1 Quote
Dylan Posted Saturday at 02:05 PM Posted Saturday at 02:05 PM 19 hours ago, migcooper said: Quick note following the replacement, worked a treat. Resilvering almost done now. Just to mention as well that I have hot plug selected in the bios for sata drives Regards Thanks for the follow up - always super helpful for users to be able to search for problems and find posted resolutions. Quote
