LuciferMstar Posted 11 hours ago Posted 11 hours ago If we can get a nice photo management app that give you the opportunity to access your gallery from distance, it would be awesome... Quote
agame7 Posted 11 hours ago Posted 11 hours ago Immich works well with that. I had to use tail scale to tunnel into it but so far no issues. 1 Quote
LuciferMstar Posted 10 hours ago Author Posted 10 hours ago 48 minutes ago, agame7 said: Immich works well with that. I had to use tail scale to tunnel into it but so far no issues. Did you try CloudFlare as tunnel solution and if yes what make you choose TailScale instead ? 1 Quote
agame7 Posted 10 hours ago Posted 10 hours ago 23 minutes ago, LuciferMstar said: Did you try CloudFlare as tunnel solution and if yes what make you choose TailScale instead ? Yeah, I tried Cloudflared though I had issues getting it connected. Tailscale worked pretty much out of the box. Quote
LuciferMstar Posted 10 hours ago Author Posted 10 hours ago Just now, agame7 said: Yeah, I tried Cloudflared though I had issues getting it connected. Tailscale worked pretty much out of the box. Awesome TY. I will give a try to TailScale. Quote
tye_the_pony Posted 6 hours ago Posted 6 hours ago (edited) 4 hours ago, agame7 said: Immich works well with that. I had to use tail scale to tunnel into it but so far no issues. im useing unifi teleport as my connection to my immich server and works extremely well Edited 6 hours ago by tye_the_pony Quote
ShadowLeRawr Posted 5 hours ago Posted 5 hours ago i used to use Piwigo as my photo management. Quote
