TheCroShow Posted 13 hours ago Posted 13 hours ago Hello, I picked up 4 Western Digital Red (4TB) SATA Hard Drives for my server, but my computer case only has 2 3.5" bays! Very frustrating! This is the case I''m using Corsair Carbide 275R I want to build my server as safe and sturdy as possible. I looked into external enclosures but it sounds like that adds a potential failure point so I'd prefer to avoid that. This article also has some better pictures inside the case. I'm not much of a hardware guy. Would love any advice short of buying a new case ='( Quote
agame7 Posted 12 hours ago Posted 12 hours ago 21 minutes ago, TheCroShow said: Hello, I picked up 4 Western Digital Red (4TB) SATA Hard Drives for my server, but my computer case only has 2 3.5" bays! Very frustrating! This is the case I''m using Corsair Carbide 275R I want to build my server as safe and sturdy as possible. I looked into external enclosures but it sounds like that adds a potential failure point so I'd prefer to avoid that. This article also has some better pictures inside the case. I'm not much of a hardware guy. Would love any advice short of buying a new case ='( if possible there might be some space near the PSU where you could zip tie those drives in it. Quote
TheCroShow Posted 12 hours ago Author Posted 12 hours ago This is my mobo, think I saw like 6-8 slots in there? Quote
TheCroShow Posted 12 hours ago Author Posted 12 hours ago I snapped a few photos of what I’m working with Quote
agame7 Posted 12 hours ago Posted 12 hours ago (edited) 10 minutes ago, TheCroShow said: I snapped a few photos of what I’m working with It is possible to sneak a drive underneath your drives and to the left-hand side of them, but if you have a backplate on it, it should be secure enough. if you cannot fit it under the drives 2 should fit next to each other on the left-hand side At least from what I see. Edited 12 hours ago by agame7 reclarification Quote
TheCroShow Posted 9 hours ago Author Posted 9 hours ago I showed a friend my situation and they're getting a 3D printer later this month, said I should setup my server with 3 HDDS (double sided tape/command strip for my 3rd HDD) then they'll print some brackets for my case so I can secure my other 2 HDDs. Hopefully setting up today! yay! Quote
syko Posted 8 hours ago Posted 8 hours ago (edited) Hdd caddy or as above, 3d print one if you know someone, have a look on etsy iv seen a few on the UK site ( not sure where your from ) That's what I had to do in my make shift nas box A 2 bay caddy could be mounted under the gpu towards the front of the case 🤔 And use the two underneath for the other 2 drivers. Edited 8 hours ago by syko Quote
ysuissa Posted 8 hours ago Posted 8 hours ago as mentioned, a steel or 3d printed caddy is the only real viable solution ("letting it hang loose" in your case would cause the drive to die pretty fast since its a spinning disk). if you're getting it 3d printed, i suggest first seeing how you can mount it in your case. you can also search thangs.com to see if someone already made a HDD caddy for your case Quote
