pacific_marvel Posted 23 hours ago Posted 23 hours ago I plan on using HexOS to run my Plex server (moving on from Synology). Would it be possible to utilize graphics card acceleration, specifically Intel Arc’s AV1 capability? Quote
Dylan Posted 11 hours ago Posted 11 hours ago (edited) You should double check but it looks like TrueNAS supports Intel ARC so it is likely that HexOS would/will support them as well - see THIS THREAD Edited 11 hours ago by Dylan remove formatting Quote
