Scyto Posted yesterday at 01:43 AM Posted yesterday at 01:43 AM (edited) if you add thunderbolt.host_reset=false to the kernel command line then nvidia eGPU will works (i have tested this and confirmed this changes works with: sudo midclt call system.advanced.update '{"kernel_extra_options": "thunderbolt.host_reset=false"}' working (note a non-working system will show D3COLD errors in the output below, this is an issue on all recent LTS and mainline kernels on systems with USB4) truenas_admin@HexOS[~]$ sudo dmesg | grep nvidia [sudo] password for truenas_admin: [ 36.563182] audit: type=1400 audit(1733276217.971:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=2363 comm="apparmor_parser" [ 36.563296] audit: type=1400 audit(1733276217.971:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=2363 comm="apparmor_parser" [ 114.962824] nvidia-nvlink: Nvlink Core is being initialized, major device number 235 [ 114.968129] nvidia 0000:39:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none [ 115.122803] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint. [ 115.148763] nvidia-uvm: Loaded the UVM driver, major device number 511. [ 115.156325] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.135 Wed Nov 13 23:35:58 UTC 2024 [ 115.161201] [drm] [nvidia-drm] [GPU ID 0x00003900] Loading driver [ 115.161203] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:39:00.0 on minor 1 [ 115.165157] [drm] [nvidia-drm] [GPU ID 0x00003900] Unloading driver [ 115.224654] nvidia-modeset: Unloading [ 115.273993] nvidia-uvm: Unloaded the UVM driver. [ 115.331235] nvidia-nvlink: Unregistered Nvlink Core, major device number 235 [ 123.378230] nvidia-nvlink: Nvlink Core is being initialized, major device number 236 [ 123.384055] nvidia 0000:39:00.0: vgaarb: VGA decodes changed: olddecodes=none,decodes=none:owns=none [ 123.507023] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.135 Wed Nov 13 23:35:58 UTC 2024 [ 123.509099] [drm] [nvidia-drm] [GPU ID 0x00003900] Loading driver [ 123.509100] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:39:00.0 on minor 1 Edited yesterday at 01:45 AM by Scyto Quote
