benlad Posted Monday at 10:43 PM Posted Monday at 10:43 PM I would like to have a mode where the system only talks to local devices and does not connect to anything over the Internet. This especially includes an offline update process where I can update via USB stick for example. 3 Quote
Almeda Posted Monday at 10:56 PM Posted Monday at 10:56 PM 12 minutes ago, benlad said: does not connect to anything over the Internet I don't think this will be added, considering that HexOS probably needs to check if your license is valid or not. Quote
Nimer Posted Tuesday at 06:13 PM Posted Tuesday at 06:13 PM 19 hours ago, Almeda said: I don't think this will be added, considering that HexOS probably needs to check if your license is valid or not. There is no way in hell they are adding always-on DRM to an OS whose whole purpose to exist is to help people be less dependent on the cloud. Quote
Magnus Posted Tuesday at 07:22 PM Posted Tuesday at 07:22 PM Hi there! An offline local UI is coming with the 1.0 release. You will need to be online for initial setup, but after that you can leave your server offline. Any features that require internet like app installs will of course not be available until you go online again. 1 Quote
