I want to use the sam system for HexOS, HomeAssistant and probably something else in the future.
Any recommendation on how to do this? I have only played around with Proxmox and that seams like a viable option.
Thank you
You can skip the virtualization with Proxmox and just run HomeAssistant directly on HexOS and run HexOS on bare-metal. For now you'll just have to go via the TrueNAS UI to do it.
Edited by Almeda
