Frostimania Posted December 1, 2024 Posted December 1, 2024 im building a nas for me and my room mate. will i need a second account to give my room mate access or will i be able to add a family member for it? Quote
0 TitanNas Posted December 1, 2024 Posted December 1, 2024 you can just add them as a users. I am not sure how many permission options they have. The license is for the hardware machine to run HEXos. So if you want a second machine or an offsite backup it would need a second purchased license. 3 Quote
0 Magnus Posted December 5, 2024 Posted December 5, 2024 Hi there! If you just want your roommate to have access to specific folders you can easily set that up. You can add as many local users as you want. Quote
0 Blackcloud327 Posted March 28, 2025 Posted March 28, 2025 I created a 2nd user but when I have them go to login with the user information on deck.hexos it says it is invalid. How do I log them in? Quote
0 PsychoWards Posted March 28, 2025 Posted March 28, 2025 What are you trying to do, the second user can get access to specified folders, but not the dashboard and shouldn't get access to the dashboard. Quote
0 Blackcloud327 Posted March 29, 2025 Posted March 29, 2025 I downloaded Immich and I was trying to get them setup with a profile to be able to dump and access their pictures and videos on there from their phone Quote
0 Blackcloud327 Posted March 29, 2025 Posted March 29, 2025 And how do they access their folders that I create for them? Quote
0 PsychoWards Posted March 29, 2025 Posted March 29, 2025 So for Immich, every user has a dedicated login, which needs to be configured in Immich and is a different user from the one you created in Hexos. The one in Hexos is meant to access the folders only and cannot access any app. No other user ever needs to access the deck. How you connected to the folder depends on your OS, but SMB is used and you should find plenty of guides on how to setup it up for your specific OS. 🙂 Quote
0 Blackcloud327 Posted March 29, 2025 Posted March 29, 2025 I downloaded the Immich app on my phone and it asks for the Server Endpoint URL. Do you know where I find that? I tried the server https/http and the IP address that it gives you when you pull the server up on a monitor but that doesn't work and Im not sure what else it would be. I just found the add user on immich but the only way I am able to access immich from my personal devices is if I login on the deck and then launch the Immich app from the deck. Quote
0 Blackcloud327 Posted March 29, 2025 Posted March 29, 2025 I finally figured it out how to login to the app after 3 days of trying and adding her as a user on it. Do you know what application I would use to make phone backups on the server so if my phone gets broken I don't loose anything? I just lost my phone like a month ago and had to pay $1,000 at a data recovery center to smart switch my device and I don't want that to happen again. But I am not sure how to do backups to the hexos server I created. Quote
Frostimania
9 answers to this question
