What harddrives are you using?
I'm looking at buying new drives for a new NAS when I get access to the beta, so was wondering what drives and how many people are using? My current plan is 4x Seagate Exos 16TB but heard from a friend that these things are great but insanely loud.
All HDD will have some kind of noise, but not that "kind of annoying" loud.
Typically you can put your NAS away from your desk, or better yet, put that in another room.
For the drives, any kind of drives is fine, Seagate Exos drives are awesome.
For HexOS, initial setup required minimum 2 drives with non expandable option, and min 3 drives with expandable option.
It's good that I went with the WD Red Plus drives, as those and the Red Pro drives are CMR.
I picked up three of the 4 TB drives so that I could add more storage to the server later after the initial setup.
I also got a pair of 256 GB M.2 drives to serve as boot drives.
I have 512 gb kioxia nvme ssd 4 6tb seagate enterprise capacity 3.5 v4 from 2016 but with only ~3 years of like use and 4 years of storage. from an old server that I built and are still healthy will be running it in a old Dell precision 3620 i7 6th gen 16gb ram during beta once it’s out of beta and I’m happy with it it will go onto my prime server which is running win 11 pro
3900x 32 gb ram multiple different ssds (6x1tb nvme in r5 (vms) and 4x2tb in r5(storage I care about) and 4x8tb exos (backups of all my computers as well as less important data as it’s not backed up) spinners in r5 and a 12tb exos for a local backup for the ssd arrays)
Edited by Cbigfoot
After spending WAY too much time evaluating disks, I landed on the 8TB version of these Seagate drives. Got 5 on sale for $150 each, so, as long as they perform and last a good amount of time, I think I'll be happy.
