Sorry if this has been mentioned already.  There needs to be a way to store a boot disk config or recovery file on one of the arrays to allow easy recover of a dead boot drive (all done within HexOS!  I shouldn't have to go into truenas if I don't know what I'm doing).  I did install on redundant boot drives but bought too cheap and they both failed simultaneously.  The only way I could find to recover was a fresh install without the array drives connected, then plug them in and manually recreate the exact share folder names in the HexOS from the list in truenas.
Also, I would love to see a way to transfer or transition the boot drive to another drive by simply connecting a new drive.  That way if all you had for a boot drive was a 1 Tb but wanted to use that for something else later you could get a smaller drive and transition.
  • 3 weeks later...
I agree I had a boot drive go down and there's no way to get back my apps without significant effort and risk of data loss.
