HighkVp Posted 3 hours ago Posted 3 hours ago So i decided to build a NAS to rip my movie collection and to tinker with some future projects when i have the time to learn about VM and AI I have a 9950x i got from a friend and 64gb of ram i bought 2 years ago for 340 dollars can you believe it i miss those times A used 5060ti 16gb found for cheap so i said to myself why not build a NAS it will be nice project during my free time. So i bought ASUS ROG Strix X870E-E Gaming motherboard , i have an old m.2 500gb for the os another 2tb nvme ssd for apps or whatever and i have two 4tb hdd laying around and i wanted something easy to use as the OS My question is what is the best approach for this build should i go for the hexOS and if yes how should i configure the ssd's to avoid any issues and i'm planning to add more hdd in the future once i figure out how to use a NAS Keep in mind I'm just a simple PC gamer never tired something like that, I'm a NAS and networking virgin. Thank you in advance any advice will help. Quote
PsychoWards Posted 1 hour ago Posted 1 hour ago Hey, that is a nice setup and will allow you to run a lot of stuff on your server 🙂 Some things to consider: You can only us the boot drive for the OS, 32GB are more then enough, 500GB are overkill, but you can still use it with 2 drives, Hexos will create a mirrored pool, which means you will have the capacity of 1 drive (4TBs in your case) and you can lose 1 drive. Additionally a mirrored Pool cannot be extended. If you want to have the possibility to extend the pool in the future, you need to have at least 3 drives now to create a RaidZ1. A RaidZ1 can be extended with additional drives in the future and you will have the capacity of your smallest drive * (the number of drives - 1) Your Motherboard has a Realtek NIC, which have a tendency to not work well or at all with Hexos. It's a new 5Gbps NIC which might work better, but keep this in mind if you face network issues. Hexos is an awesome, easy to use OS and offers exactly what you need to get started. It offers both Plex and Jellyfin as 1 click install apps, so that you have the choice what you want to use. It also offers other popular apps as 1 click installs and more apps will be supported in the future. Quote
