When booting the system I get an error for Kernel Panic, mentions something about unable to mount zfs and having a kernel offset. When it boots I have the option to boot into 4 different HexOS versions, all of them have the same issue.
I kept the main install drive untouched so I can trouble shoot on it, I had the idea of using another spare drive to reinstall HexOS and within the TrueNAS interface see if my data is alright, and it seems to be. Using zpool I can mount it, but only as read only, if I change read only off it crashes.
The last time my HexOS system was working as intended, it froze and I had to hold the power button to reset it, so I am thinking maybe it froze in the middle of doing something with the pool? I can access my data, but I do not have any drives large enough to migrate all the date off and move it back on. All my data is backed up else where scattered around so if the pool is lost it is not the end of the world, just a lot of work to set it back up.
Any advice is appreciated. Thank you in advanced! I am also willing to hop on a discord call with anyone if they would like to work through this with me.
You can post now and register later.
If you have an account, sign in now to post with your account.
Rampage0220
0 answers to this question
