Pasquizle Posted December 29, 2025 Posted December 29, 2025 (edited) TLDR: does Jellyfin support ARC A310 for hardware acceleration in Jellyfin or does Intel 12/13/14th gen iGPU support AV1/strong enough for multiple 4k transcoded streams I've been running a Jellyfin server for myself and friends and I use my own Blu-ray rips so they can be pretty intense on bandwidth, especially my 4k rips. some of my friends have bad internet so they'd need to transcode it to a lower quality but my current setup is mini itx (to fit in my small apartment until I move and have a larger area to set it up) and currently only has an i7 6700 so the igpu doesn't support 4k qsync and 4k transcode is WAY too intense for it. So I was wandering which GPUs are supported in HexOS so that when I move and upgrade my system I have a compatible GPU, I'm also open to recommendations, I currently have a GTX 1650 lying around but If an arc a310 is supported I'd love the AV1 support. But again if there's other options that have lower power draw/cost I'm more than open to suggestion! I have a B660 board in it's box so if intel 12/13/14 iGPUs support AV1 AND can handle multiple 4k transcoded streams that would be great to know, thank you very much for taking the time to read Edited December 29, 2025 by Pasquizle Forgot to specify 12/13/14th gen iGPU Quote
Mobius Posted December 29, 2025 Posted December 29, 2025 arc a310 should be supported, with its support being added in 25.04. the igpu from those generations is likely good enough for multiple 4k streams however that generation of intel igpu does not support av1 transcoding. Most power efficient option would be getting yourself an intel core ultra cpu as those igpus support av1. 1 Quote
