Problem with qbittorrent for adding duplicate .torrent!
I just updated my deck.os server and reseted my Qbittorrent app.
The problem i have now, i can't add duplicate .torrent to my app!
That is a pain, because i uploaded some torrent to a website and continue to share on another website.
Normally, i just readd the .torrent to qbitorrent and it's pointed to the file location, but now when i add a duplicate torrent, nothing happen. No warning text box or starting checking file or showing in my list of torrent.
I try to put on a different directory the file and try to redownload on my default directory and still nothing.
They are from a private torrent, i can't add the tracker manually on the torrent.
If someone have found a fix for that, i will appreciate.
Thx in advance.
PS: sorry for my english, it's not my main language!!!
This is a qbittorrent limitation/feature. if the infohashes are the same then qbitorrent will treat them as the same torrent and not create a duplicate entry.
you may want to search info on best ways to cross-seed online.
