see.dante Posted 2 hours ago Posted 2 hours ago I'm wondering what the recommendations for a low power setup. Since HexOS isn't arm compatible, I'm wondering if there recommendations are. If anyone has success with a low idle setup, would love to know! Quote
Mobius Posted 2 hours ago Posted 2 hours ago here are some low power server builds (not necessarily on hexos/truenas) https://docs.google.com/spreadsheets/d/1LHvT2fRp7I6Hf18LcSzsNnjp10VI-odvwZpQZKv_NCI/edit?gid=0#gid=0 These are just some general things to keep in mind you can can expect each hdd and ssd to add 2-7w at idle. not using a gpu will save you 10-20w at idle keeping peripherals unplugged (monitor, keyboard, mouse) help a bit old amd cpus have trouble if c states are enabled. fan power draw ads up skip the rgb Quote
