I am trying to install Immich and it has been stuck installing for almost 30 minutes. I have successfully installed other apps, but cannot cancel or get Immich to complete.
Edited by kenlew
Is there a way to cancel the task so it isn't stuck? Or so that I can try and re-install it?
Edit: I had to manually install it from the TrueNAS UI, then uninstall it from HexOS to get it unstuck.
Edited by kenlew
