perplexed3006 Posted October 21, 2025 Posted October 21, 2025 I have just setup a new server using a Minisforum MS-A2 all SSD. Have installed Homeassistant through the Curated App installer. I didnt modify any of the default settings. I went to do a Restore in Home Assistant via the upload backup option. The backup uploaded but failed to restore with: [Errno 16] Resource busy: PosixPath('/config/postgres_data') I tried a few more times but same I rebooted Hexos from the deck when i logged back in after the reboot i saw notifications: Any advice? have other people had any similar warnings? Thanks Quote
perplexed3006 Posted October 21, 2025 Author Posted October 21, 2025 It looks like the App curation process has something amiss. here is the error from the truenas section. I gather ACL is something to do with permissions? Can anyone decipher this so i can fix it? Quote
perplexed3006 Posted October 21, 2025 Author Posted October 21, 2025 Sorry, I just realised that this thread should be Moved, but I cant figure out how to move it. Could one of the Mods please move to https://hub.hexos.com/forum/30-home-assistant/ Quote
perplexed3006 Posted October 21, 2025 Author Posted October 21, 2025 Thanks to Upon furthur digging in the truenas maze I have found that the folder mentioned above (SSDs/Applications/home-assistant/postgres_data) has the ACL Mode set to Discard, but I cant change it. Quote
Shong Posted January 13 Posted January 13 Did you have any luck with this? im still stuck on the same issue despite changing to passthrough Quote
