Fresh install of HexOS, Fresh install of Home Assistant, logs full of errors, Home Assistant not working.
I've freshly installed HexOS and added the home assistant application. -- I've left everything default.
Home Assistant's log is full of errors, and it doesn't retain any configuration between reboots.
It looks like HexOS/TrueNAS isn't installing Home Assistant correctly, and there are some permissions problems.
I'm out of my depth here. I've uninstalled, deleted the left-over datasets and reinstalled a few times, always with the same result.
Should I reinstall HexOS at this point? why does this even happen
2025-10-10 11:55:09.957 ERROR (SyncWorker_6) [homeassistant.util.file] Saving file failed: /config/.storage/http.auth
Traceback (most recent call last):
  File "/usr/src/homeassistant/homeassistant/util/file.py", line 62, in write_utf8_file
    os.fchmod(fdesc.fileno(), 0o644)
PermissionError: [Errno 1] Operation not permitted
2025-10-10 11:55:09.958 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for http.auth: [Errno 1] Operation not permitted
2025-10-10 11:55:11.433 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
  File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 386, in async_populate
    await self.hass.async_add_executor_job(populate)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 381, in populate
    shutil.copytree(
        integration.file_path / BLUEPRINT_FOLDER,
        self.blueprint_folder / HOMEASSISTANT_DOMAIN,
  File "/usr/local/lib/python3.13/shutil.py", line 593, in copytree
    return _copytree(entries=entries, src=src, dst=dst, symlinks=symlinks,
                     ignore=ignore, copy_function=copy_function,
                     ignore_dangling_symlinks=ignore_dangling_symlinks,
                     dirs_exist_ok=dirs_exist_ok)
  File "/usr/local/lib/python3.13/shutil.py", line 547, in _copytree
    raise Error(errors)
shutil.Error: [('/usr/src/homeassistant/homeassistant/components/automation/blueprints/notify_leaving_zone.yaml', '/config/blueprints/automation/homeassistant/notify_leaving_zone.yaml', "[Errno 1] Operation not permitted: '/config/blueprints/automation/homeassistant/notify_leaving_zone.yaml'"), ('/usr/src/homeassistant/homeassistant/components/automation/blueprints/motion_light.yaml', '/config/blueprints/automation/homeassistant/motion_light.yaml', "[Errno 1] Operation not permitted: '/config/blueprints/automation/homeassistant/motion_light.yaml'"), (PosixPath('/usr/src/homeassistant/homeassistant/components/automation/blueprints'), PosixPath('/config/blueprints/automation/homeassistant'), "[Errno 1] Operation not permitted: '/config/blueprints/automation/homeassistant'")]
2025-10-10 11:55:11.436 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
    shutil.copytree(
    raise Error(errors)
shutil.Error: [('/usr/src/homeassistant/homeassistant/components/script/blueprints/confirmable_notification.yaml', '/config/blueprints/script/homeassistant/confirmable_notification.yaml', "[Errno 1] Operation not permitted: '/config/blueprints/script/homeassistant/confirmable_notification.yaml'"), (PosixPath('/usr/src/homeassistant/homeassistant/components/script/blueprints'), PosixPath('/config/blueprints/script/homeassistant'), "[Errno 1] Operation not permitted: '/config/blueprints/script/homeassistant'")]
2025-10-10 11:55:11.671 ERROR (SyncWorker_6) [homeassistant.util.file] Saving file failed: /config/.storage/core.restore_state
2025-10-10 11:55:11.672 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.restore_state: [Errno 1] Operation not permitted
2025-10-10 11:55:12.803 ERROR (SyncWorker_7) [homeassistant.util.file] Saving file failed: /config/.storage/core.config_entries
2025-10-10 11:55:12.804 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.config_entries: [Errno 1] Operation not permitted
2025-10-10 11:55:21.050 ERROR (SyncWorker_3) [homeassistant.util.file] Saving file failed: /config/.storage/assist_pipeline.pipelines
2025-10-10 11:55:21.053 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for assist_pipeline.pipelines: [Errno 1] Operation not permitted
2025-10-10 11:55:21.674 ERROR (SyncWorker_6) [homeassistant.util.file] Saving file failed: /config/.storage/homeassistant.exposed_entities
2025-10-10 11:55:21.675 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for homeassistant.exposed_entities: [Errno 1] Operation not permitted
2025-10-10 11:55:21.803 ERROR (SyncWorker_1) [homeassistant.util.file] Saving file failed: /config/.storage/core.device_registry
  File "/usr/src/homeassistant/homeassistant/util/file.py", line 38, in write_utf8_file_atomic
2025-10-10 11:55:21.805 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.device_registry: [Errno 1] Operation not permitted
2025-10-10 11:55:21.806 ERROR (SyncWorker_8) [homeassistant.util.file] Saving file failed: /config/.storage/core.entity_registry
2025-10-10 11:55:21.807 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.entity_registry: [Errno 1] Operation not permitted
2025-10-10 11:58:09.925 ERROR (SyncWorker_2) [homeassistant.util.file] Saving file failed: /config/.storage/repairs.issue_registry
2025-10-10 11:58:09.926 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for repairs.issue_registry: [Errno 1] Operation not permitted
2025-10-10 11:58:10.001 ERROR (SyncWorker_0) [homeassistant.util.file] Saving file failed: /config/.storage/http
2025-10-10 11:58:10.002 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for http: [Errno 1] Operation not permitted
2025-10-10 12:10:11.006 ERROR (SyncWorker_7) [homeassistant.util.file] Saving file failed: /config/.storage/bluetooth.passive_update_processor
2025-10-10 12:10:11.007 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for bluetooth.passive_update_processor: [Errno 1] Operation not permitted
2025-10-10 12:10:11.673 ERROR (SyncWorker_5) [homeassistant.util.file] Saving file failed: /config/.storage/core.restore_state
2025-10-10 12:10:11.675 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.restore_state: [Errno 1] Operation not permitted
2025-10-10 12:25:11.006 ERROR (SyncWorker_3) [homeassistant.util.file] Saving file failed: /config/.storage/bluetooth.passive_update_processor
2025-10-10 12:25:11.009 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for bluetooth.passive_update_processor: [Errno 1] Operation not permitted
2025-10-10 12:25:11.673 ERROR (SyncWorker_6) [homeassistant.util.file] Saving file failed: /config/.storage/core.restore_state
2025-10-10 12:25:11.675 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.restore_state: [Errno 1] Operation not permitted
2025-10-10 12:27:02.148 ERROR (SyncWorker_1) [homeassistant.util.file] Saving file failed: /config/.storage/person
2025-10-10 12:27:02.151 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for person: [Errno 1] Operation not permitted
2025-10-10 12:27:02.151 ERROR (SyncWorker_4) [homeassistant.util.file] Saving file failed: /config/.storage/core.area_registry
2025-10-10 12:27:02.153 ERROR (SyncWorker_7) [homeassistant.util.file] Saving file failed: /config/.storage/core.entity_registry
2025-10-10 12:27:02.155 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.area_registry: [Errno 1] Operation not permitted
2025-10-10 12:27:02.155 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.entity_registry: [Errno 1] Operation not permitted
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain sun.sensor
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain energy.sensor
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain backup.event
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain mobile_app.notify
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain backup.sensor
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain homeassistant.scene
2025-10-10 12:27:10.152 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain cloud.tts
2025-10-10 12:27:10.153 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain google_translate.tts
2025-10-10 12:27:10.153 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Invalid domain sun.binary_sensor
2025-10-10 12:27:11.248 ERROR (SyncWorker_5) [homeassistant.util.file] Saving file failed: /config/.storage/core.analytics
2025-10-10 12:27:11.251 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.analytics: [Errno 1] Operation not permitted
2025-10-10 12:27:11.505 ERROR (SyncWorker_2) [homeassistant.util.file] Saving file failed: /config/.storage/core.config_entries
2025-10-10 12:27:11.507 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.config_entries: [Errno 1] Operation not permitted
2025-10-10 12:27:12.310 ERROR (SyncWorker_1) [homeassistant.util.file] Saving file failed: /config/.storage/lovelace.map
2025-10-10 12:27:12.322 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for lovelace.map: [Errno 1] Operation not permitted
2025-10-10 12:27:20.157 ERROR (SyncWorker_2) [homeassistant.util.file] Saving file failed: /config/.storage/repairs.issue_registry
2025-10-10 12:27:20.159 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for repairs.issue_registry: [Errno 1] Operation not permitted
2025-10-10 12:27:20.460 ERROR (SyncWorker_4) [homeassistant.util.file] Saving file failed: /config/.storage/core.entity_registry
2025-10-10 12:27:20.461 ERROR (SyncWorker_8) [homeassistant.util.file] Saving file failed: /config/.storage/core.device_registry
2025-10-10 12:27:20.464 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.entity_registry: [Errno 1] Operation not permitted
2025-10-10 12:27:20.464 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.device_registry: [Errno 1] Operation not permitted
2025-10-10 12:27:22.306 ERROR (SyncWorker_7) [homeassistant.util.file] Saving file failed: /config/.storage/lovelace_dashboards
2025-10-10 12:27:22.309 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for lovelace_dashboards: [Errno 1] Operation not permitted
Looks like I have the same issue. Spent an hour last night setting up Home Assistant for the first time and connecting all my devices. Opened it again today to view some stats only to see a message that I have no devices set up...
Logs:
Quote
2025-10-17 23:45:45.676 ERROR (SyncWorker_3) [homeassistant.util.file] Saving file failed: /config/.storage/http.auth
2025-10-17 23:45:45.677 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for http.auth: [Errno 1] Operation not permitted
2025-10-17 23:45:56.422 ERROR (SyncWorker_2) [homeassistant.util.file] Saving file failed: /config/.storage/core.restore_state
2025-10-17 23:45:56.423 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.restore_state: [Errno 1] Operation not permitted
2025-10-17 23:45:57.478 ERROR (SyncWorker_2) [homeassistant.util.file] Saving file failed: /config/.storage/core.config_entries
2025-10-17 23:45:57.479 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.config_entries: [Errno 1] Operation not permitted
2025-10-17 23:46:04.518 ERROR (SyncWorker_6) [homeassistant.util.file] Saving file failed: /config/.storage/assist_pipeline.pipelines
2025-10-17 23:46:04.519 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for assist_pipeline.pipelines: [Errno 1] Operation not permitted
2025-10-17 23:46:06.425 ERROR (SyncWorker_2) [homeassistant.util.file] Saving file failed: /config/.storage/homeassistant.exposed_entities
2025-10-17 23:46:06.426 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for homeassistant.exposed_entities: [Errno 1] Operation not permitted
2025-10-17 23:46:06.477 ERROR (SyncWorker_1) [homeassistant.util.file] Saving file failed: /config/.storage/core.device_registry
2025-10-17 23:46:06.478 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.device_registry: [Errno 1] Operation not permitted
2025-10-17 23:46:06.479 ERROR (SyncWorker_4) [homeassistant.util.file] Saving file failed: /config/.storage/core.entity_registry
2025-10-17 23:46:06.479 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for core.entity_registry: [Errno 1] Operation not permitted
2025-10-17 23:47:44.612 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/miio/miot_device.py:23: FutureWarning: functools.partial will be a method descriptor in future Python versions; wrap it in enum.member() if you want to preserve the old behavior
Bool = partial(_str2bool)
2025-10-17 23:48:45.967 ERROR (SyncWorker_5) [homeassistant.util.file] Saving file failed: /config/.storage/http
2025-10-17 23:48:45.968 ERROR (MainThread) [homeassistant.helpers.storage] Error writing config for http: [Errno 1] Operation not permitted
im no expert on permissions (and i don't even use HA) but, when you remade the data sets did you select the apps preset?
I ran into the same problem, and this fixed it. I think the install script for HexOS for this app needs to be modified slightly. Made a data set in the home-assistant folder, give it a name like "config" or "data", and modify the "Host Path" for "Home Assistant Config Storage" to be in that new dataset. Now I need to look at how to remove a bunch of junk from a folder without removing the datasets I want.
 image.thumb.png.6ada4b593be1e73e7f21b6ed17385e3d.pngimage.png.28da77fe4416b903cc5e413354c7cbbb.png
  • Thanks 2
  • 3 weeks later...
Thanks for this, it worked for me too. Before trying this, I tryed to create a new instance manually in truenas but ran into certificate issue.
  • 1 month later...
22 hours ago, xaliax said:
Do anyone know if this install script has been fixed/modified yet?
Nope ;( ran into the same problem today lost all my intergrations after needed to be shut down to add a USB device
I followed the VM guide and its working great!
  • 5 weeks later...
Creating the config dataset when using the defauult HexOs app install was the fix for me also,
Thanks for this wkwebster
  • 2 weeks later...
This fixed my issue I was having with HA, thank you! 🙏
