Will HexOS enable us to use mirrored SSDs for sync writes, metadata, and small files, aka SLOG & special vdev?
Hello! Are there plans for HexOS to allow users to use (mirrored) SSDs for ZFS' tiered storage optimizations?
The main three uses I'm thinking of:
  • Enable high-endurance mirrored SSDs to accept synchronous writes (SLOG)
  • Enable mirrored SSDs to store all file metadata (special vdev)
  • Enable mirrored SSDs to store all small files (special vdev)
While I'm sure popping into TrueNAS (for those with that experience) would work, I think implementing these directly in HexOS would be quite beneficial even for consumers with many small files and / or macOS devices.
While not all performance-based vdevs are helpful in most scenarios, these would be great, especially the special vdev for small files, e.g., use the ultra-fast random access of SSDs for video editing project files or documents (special vdev) and especially the SLOG vdev for macOS SMB writes (always sync writes).
Of course, in some far and away future, HexOS would identify when these vdevs would significantly improve performance, but manually turning them on & testing them out would also be neat through HexOS. I'm intentionally ignoring L2ARC, which requires much more careful hardware selection & tuning to get any benefit.
7 answers to this question
  • 1
i'm not gonna go as far as saying never gonna happen but i'd say its on the furthest back burner if at all.
special vdev is a scary one to implement because if it goes down, itll take the whole pool down with it on top of not being very useful for most homelab users
slog also doesn't make the most sense for most users as to my best understanding it only really protects you in case of power loss and at that point you might be better served just getting a ups.
Personally i do run a triple mirror special vdev on my storage pool and i think it causes some stability issues with hexos.
Thank you for your reply, @Mobius. That does make sense. To your final note, hopefully by stable, if we manually create these vdevs in TrueNAS, they can play nicely with HexOS.
I agree: I believe folks recommend the special vdev to have the same redundancy as the data vdevs; if it were to be added, hopefully that recommendation could be prominent. I've heard mixed things about performance: for many-file directories, it can feel snappier, which is what I hope.
SLOG: ah, I had another angle. My main interest are a couple of wired Macs on our network as Macs write to SMB synchronously (straight to HDDs), without fast RAM-first writes like Windows machines. But with an SLOG, Macs write to this faster SLOG vdev, allowing the transfer to complete faster. So with an SLOG, Macs have virtually identical write performance as Windows. But without the SLOG, Macs write a little slower.
We definitely use a UPS; it's a solid investment for data integrity as you get PLP for the whole server! A great recommendation.
I could be wrong but afaik slog wouldn't really increase speeds since it'll only hold a couple seconds of transfer time only.
client > server RAM > SLOG > pool (HDD/SSD)
Regardless of what os you access from
I'm curious, I got HexOS to support them but haven't really been utilizing it because it didn't seem like it was using my special vdev for metadata. When I set up the metadata drives in truenas and everything is confirmed, when I go back to the HexOS interface it shows those drives as unallocated so I'm never sure if the apps I'm installing through HexOS are going to utilize those drives. Also note, it's been a while since I've tried setting it up because I don't particularly like to tinker, so this might have been fixed already and I'm just unaware.
hexos will not show the drives as used as support for special vdev in the hexos interface was never added.
once a special vdev is added to a pool, their use is automatic. You don't have to worry about hexos seeing or not seeing it correctly.
Just to verify, if I create the pool and vdev in truenas. Even though HexOS sees the pool of 4 drives and shows the 2 optane drives as unused/unallocated (truenas shows correctly assigned) the apps and data installed through hexos like immich would correctly be using the optane drives for metadata?
I'm honestly not even sure how to verify, I had set it up and threw a couple hundred photos but couldn't tell (mostly because beyond storage capacity I don't know what i'm looking for to validate) whether or not the metadata was going on the optane or just written to the discs in the pool.
yes. keep in mind that how metadata/special vdevs work is that your index for your storage drives (like the table of contents) get added to it, which can speed up things when yo have say 1000s of folders with 1000s of folders in them. They also store all the files below a certain size (can be changed via truenas interface)
Also apps created via the hexos interface work exactly the same if created through the truenas interface
the way to check would be to run some shell commands in the truenas interface, you would get an output like this
Quote
steps to check
1) enter truenas interface
2)enter the systems tab on the bottom left
3) enter shell
4) type "sudo zpool iostat -v <name of pool>"
5) itll ask for a password, your keystrokes don't show as a security feature
5) add a bunch of small files to your pool
6) run the command again and check if the special vdev increased in size.
Answer this question...
