I’ve changed the default port numbers on my TrueNAS web server to free up ports 80 and 443 for other services. However, from the HexOS portal, it still tries to connect using the standard ports when interacting with TrueNAS.
For example, if I try to edit an app’s configuration or launch the TrueNAS configuration from the portal, I don’t get the correct interface. It would be great if the portal could detect the configured port numbers via the API, or allow these to be set manually in the HexOS settings.
  • Like 3
  • 2 months later...
