about to click and buy
the one question i presume i want to no will they give a link to to install a fresh and  when i buy as still sorting the server out as i run  three truenas servers all have Version:
25.04.1 on them  thankyou as soon as i get reply hoping so i will hit buy button
2 answers to this question
Hey,
I'm not sure if I understand you question, but yes you will find a link to download the OS which you then need to install as a new OS. During the installation process you can choose to skip the creation of a new pool if you want to import an existing pool. This however has then to be done in the truenas GUI.
As for Hexos, it only supports Truenas 24.10.2.X. 25.04 is currently not supported and will break some functions/displays in Hexos.
Answer this question...
