i want to no if this will be ok for hexos
870 motherboard
AMD Ryzen 7 8700G w/ Radeon 780M Graphics
64gig ddr5
asus xg-c100c network card
LSI 9300-16i 16-Port 12Gb/s SAS/SATA HBA ZFS TrueNAS UnRAID IT Mode 16.00.12.00
hmmm what do you plan to use your server for mainly?
if its something like plex or jellyfin then intel cpus might still work better for you since intel quick sync is still great for transcoding video.
if its mostly other stuff your ryzen 8700g shouldnt have any issues
14 minutes ago, hammerdown said:
64gig ddr5
defintely a healthy amount of ram
this may or may not give you issues (like pretty much every nic on the market)
seems like it uses either a Aquantia AQC107 chipset or the newer AQC113 chipset
i am not incredibly familiar with aquantia compatibility.
i would definitely google around "Aquantia AQC### truenas scale" and see what kind of experiences others have had
highly recommend at least stepping up to a lsi 9305 or lsi 9400 because the 9300 runs super hot and chuggs on electricity.
Getting a card with IT mode, like you picked, is a must
i plan to use for plex  and i can confirm  the asus nic works
