Mindless999 Posted September 11 Author Posted September 11 Quick update on this, I had 2 failures of the verbatim (OS) disks in a short time already, so I would recommend going for different OS disks. Because they were 256, and other decent brands didn't really have something similar, I needed to put in bigger disks to replace this with those disks. So, if you can, put in things like, Seagate, Samsung, Corsair etc. Quote
Mobius Posted September 12 Posted September 12 6 hours ago, Mindless999 said: Quick update on this, I had 2 failures of the verbatim (OS) disks in a short time already, so I would recommend going for different OS disks. Because they were 256, and other decent brands didn't really have something similar, I needed to put in bigger disks to replace this with those disks. So, if you can, put in things like, Seagate, Samsung, Corsair etc. yikes, thats super unlucky. verbatim had a reputation for making quality drives so im quite surprised. Quote
positive vibezz Posted September 14 Posted September 14 On 5/17/2025 at 2:07 PM, Mobius said: I tried to keep to a similar budget and made the build i would rather have for the price. https://nl.pcpartpicker.com/list/Wb3wZc cpu: 12700k - cheapest cpu with intel uhd 770 igpu Mobo: asus something or other - has intel nic so theoritcally shouldn't cause you trouble and i like asus motherboards ram: gskill 64gb 5200mhz cl36 - slightly cheaper ram that is slightly faster and personally i like gskill ram, its the only brand i purchase ram from anymore cooler: thermalright peerless assassin 90 - its cheaper, should still fit in case and a reoccuring theme here, i like thermalright coolers os drive - cheaper ssd - its as big as you need, significantly cheaper, from a trusted brand and for fun i made it a triple mirror storage drive- 24tb exos, i like going with big drives and there are 4 of them because we can lol psu: went for a cheaper 750w psu because you have no need for a 850w even at max capacity, we could go even smaller but this one is very efficient edit: seems like i was typing this out before your newest post, so i'll look into it edit 2: i would say just take my list and adjust storage to your preferred budget you may even be able to find new exos drives for less on ebay but as i'm in a different part of the world than you its hard for me to check just make sure with any segate drives your purchase, regardless of how trusted the retailer is, you check the farm data to see if it actually is new. i think 64 gigs is not needed 48 gigs is a better sweet spot Quote
Mindless999 Posted September 20 Author Posted September 20 And I do run some VM's on it as well / applications. So I prefer to have more memory, than to not have enough. 🙂 Quote
