permission issues
All my public shares are working fine.
When I went to create and access some private shares.  windows keeps saying access is denied and i dont have permission
The user name and password im using is correct
2 answers to this question
  • 1
Did you ever figure out the solution for this?
Hexos definitely doesn't make it more simple.
One day i have access on "apps" & "user", next password incorrect for "user", i fix that and then i loose access to "apps", now lost access to both.
Spent the last few days trying to figure it out, but with zero luck. HEX OS simple users and SMB sharing is 100% BROKEN, outdated completely now apps are outdated in Truenas dashboard.
So much for simplicity.
I DON'T WANT DO DEAL WITH ACL's, and it seams they are broken too.
Answer this question...
