Thedoh Posted December 28, 2024 Posted December 28, 2024 I can't find it anywhere in searching the forums. But from what I see a dedicated GPU will work with plex ect if done through truenas. Currently, if I have an arc A380 installed am I correct in the fact that it doesn't show up under hardware? I don't see it. Hopefully they will have support soon enough. Quote
HomeHosted Posted December 28, 2024 Posted December 28, 2024 (edited) 15 hours ago, Thedoh said: I can't find it anywhere in searching the forums. But from what I see a dedicated GPU will work with plex ect if done through truenas. Currently, if I have an arc A380 installed am I correct in the fact that it doesn't show up under hardware? I don't see it. Hopefully they will have support soon enough. Seems as if the older Intel Arc GPUs are supported. https://forums.truenas.com/t/accepted-add-intel-gpu-tools-package-to-scale/8971/4 https://ixsystems.atlassian.net/browse/NAS-130356 I would give it some time and a newer kernel will comes to TrueNAS, then it will require HexOS to also update their system to be tested and released with that updated TrueNAS Scale Version, it will be a bit most likely, for the newer ones. But your A380 should be supported per these post. Edited December 28, 2024 by HomeHosted Quote
Thedoh Posted December 28, 2024 Author Posted December 28, 2024 32 minutes ago, HomeHosted said: Seems as if the older Intel Arc GPUs are supported. https://forums.truenas.com/t/accepted-add-intel-gpu-tools-package-to-scale/8971/4 https://ixsystems.atlassian.net/browse/NAS-130356 I would give it some time and a newer kernel will comes to TrueNAS, then it will require HexOS to also update their system to be tested and released with that updated TrueNAS Scale Version, it will be a bit most likely, for the newer ones. But your A380 should be supported per these post. Thanks for the response, So all in all, it more or less is supported, just need to wait for an update from Hexos to show it under the hardware tab, and I would assume it can be enabled for encoding once Jellyfin is done under hex. Quote
