Syko Posted December 14, 2024 Posted December 14, 2024 Not sure if this is the place to ask , Been looking at this switch .. but not sure if i use it as a stand alone switch or do i need any other of the Ubiquiti hardware to run the switch? https://uk.store.ui.com/uk/en/products/usw-flex-2-5g-5 Quote
Dylan Posted December 14, 2024 Posted December 14, 2024 5 hours ago, Syko said: Not sure if this is the place to ask , Been looking at this switch .. but not sure if i use it as a stand alone switch or do i need any other of the Ubiquiti hardware to run the switch? https://uk.store.ui.com/uk/en/products/usw-flex-2-5g-5 From what I can tell, if you have existing PoE or USB-C powered sources then you wouldn't need to use the included EU power cable. Quote
Syko Posted December 15, 2024 Author Posted December 15, 2024 Thanks but quite what is was asking , which is , 🙂 I have a Sodola network switch , but want to replace it with the Flex mini 2.5gb but i don't have any other Ubiquiti equipment . is it possible to use the flex mini just by it's self ? Quote
Mawson Posted December 15, 2024 Posted December 15, 2024 I believe it's possible, but I'm not sure how challenging it would be to configure it without having a cloud key or unifi gateway (router) https://store.ui.com/us/en?category=all-cloud-keys-gateways Quote
Master-spud Posted December 15, 2024 Posted December 15, 2024 I'm sure as just a dummy switch it would work on it's own, all the added functionality of being a smart switch would be out the window without either hosting the Ubiquiti software on your computer (I did this with a few of their access points before finally getting a unifi gateway) or buying one of their other methods of having the unifi software running. So yes and no... Quote
