JaranNL Posted December 9, 2024 Posted December 9, 2024 I haven’t been able to find information on whether the Areca hardware RAID card is supported in HexOS (a driver install is required). Does anyone have experience or insights on this? Any help would be greatly appreciated! Quote
Dylan Posted December 9, 2024 Posted December 9, 2024 5 hours ago, JaranNL said: I haven’t been able to find information on whether the Areca hardware RAID card is supported in HexOS (a driver install is required). Does anyone have experience or insights on this? Any help would be greatly appreciated! You shouldn't really need a raid card. ZFS manages all of that for you. Quote
JaranNL Posted December 10, 2024 Author Posted December 10, 2024 11 hours ago, Dylan said: You shouldn't really need a raid card. ZFS manages all of that for you. Hi Dylan, Thanks for this, but would it be possible if I chose to use it? Quote
Dylan Posted December 10, 2024 Posted December 10, 2024 2 hours ago, JaranNL said: Hi Dylan, Thanks for this, but would it be possible if I chose to use it? Hey JaranNL. You are free to use a raid card if you choose however it will likely remain an unsupported configuration. It might be helpful to use the search function on this forum (found under "Activity') and take a look at other experiences. Quote
